01-11-2020, 04:07 PM
I might just be misunderstanding this feature.
I assumed the midi start/stop output setting sent only midi start/stop signals.
I assume that if I set midi start/stop output to "all" that it should not interact with the midi assignments for drone, pad, and motifs.
But when I set the midi start/stop output to "all" it wildly interferes with what is being sent to the other midi outs. It seems like the start/stop output is sending notes also!
My NDLR is ths most ROCK SOLID midi clock of my entire setup and my Blofeld depends on this, otherwise it "clicks" eg as Ableton tempo drifts. But I need NDLR to output start/stop to usb AND midi without interacting otherwise. Is that possible?
Thanks!
Thanks!
