11-02-2021, 09:13 AM
I am seeing some odd behavior with my MRCC and its USB ports.
I have an M8 (Handheld tracker) which has both midi din in/out (1/8th") and midi over USB. I have a very simple sequence on a single midi channel playing on the M8. It is sending clock, transport, and program change .
1. When sending this channel out to a synth (Intellijel Palette Midi 1u) via midi din (out port 7) the sequence plays perfectly. However, when I try to route the same data to the USB port on the Palette (USB in/out A on the MRCC) I get randomly skipped notes/ CC data. Clock & start/stop are still sent fine.
2. The other problem I am seeing with my USB ports is that the M8 USB out (fully class compliant) is ignored (no data at all registers on the MRCC).
3. And finally I am getting Hard locks about 25% of the time on the MRCC if I cycle power on the Intellijel Palette while the USB is plugged into the MRCC.
I have been slowly debugging this the last few days, so if you need additionaly info/ video I can certainly add that
