I can't get the strum to work at all when using an external clock. As soon as I switch it to internal clock, then strum works as it should. With external clock only the default, no-strum pad trigger will sends any note data — all other strum settings result in silence, essentially killing the pad channel.
Strum not working with external clock
03-19-2019, 12:05 AM
I experienced the same with Pad... which was due to NDLR Cntrl and KB Trans being on the same channel
03-19-2019, 08:54 AM
(03-18-2019, 11:36 PM)leave trace Wrote: I can't get the strum to work at all when using an external clock. As soon as I switch it to internal clock, then strum works as it should. With external clock only the default, no-strum pad trigger will sends any note data — all other strum settings result in silence, essentially killing the pad channel. Thanks for posting this sighting! Did MKS30’s suggestion help? I’ll have a look today and try to reproduce your sighting. There was a similar bug with the modulation matrix having to do with internal v. external Clock. It might be the same issue in a different location. Steve
03-19-2019, 01:32 PM
The external clock was not triggering the strummed notes. Also the initial Pad "play" wouldn't strum. These have been fixed and will be posted in a FW update soon.
Steve
03-19-2019, 01:53 PM
Thanks Steve!
« Next Oldest | Next Newest »
| 2 Guest(s) |
