Threads: 13
03-18-2019, 11:36 PM
I can't get the strum to work at all when using an external clock. As soon as I switch it to internal clock, then strum works as it should. With external clock only the default, no-strum pad trigger will sends any note data — all other strum settings result in silence, essentially killing the pad channel.
Threads: 4
I experienced the same with Pad... which was due to NDLR Cntrl and KB Trans being on the same channel
Threads: 11
The external clock was not triggering the strummed notes. Also the initial Pad "play" wouldn't strum. These have been fixed and will be posted in a FW update soon.
Steve
