Changing chords via midi CC message?
In the manual's Appendix, for MIDI CC (Control Change) Implementation, to change the chord it indicates CC # 26, values 1-6.   But, there are seven chords that can be chosen.    Same thing for the Chord Type on CC #27.    Are these supposed to be values 0 - 6 ?  See attached image
Attached Files Thumbnail(s)
(08-26-2020, 03:12 PM)RobertBeach00 Wrote: In the manual's Appendix, for MIDI CC (Control Change) Implementation, to change the chord it indicates CC # 26, values 1-6.   But, there are seven chords that can be chosen.    Same thing for the Chord Type on CC #27.    Are these supposed to be values 0 - 6 ?  See attached image
I'm almost certain that you are correct. It's either 0-6 or 1-7. I'll put this in the bug tracking list and get that sorted out and update the manual.
Thanks.
EDIT: I just went to the downloads page and looked at the most recent version of the manual and it's already been corrected, the correct range should be 1-7 for both Degree and Chord Type.
https://conductivelabs.com/download/
Thanks!
