05-01-2025, 11:24 AM
Hello,
When making some tests about the transpose issue, I came accross a weird but reproductible problem : modifier stop responding to input, it seems freezed.
There is a simple pattern, easily reproductible.
One source, tree ouputs. (or 4 outputs)
For the first ouput, set a modifiers, I had a T1 modifier.
Nothing need for ouput 2 and 3
When you look the MRCC output, output 1 is the left most, the other two came after to the right (this is important, order matters)
Now, just remove output 1 from the routing.
Try to set a modifiers in the output 2 (which was notmally auto selected), it works.
try the same from ouput 3, it won't work anymore.
=> you have to reselect the output 1 to re-enable the modifiers in ouput 3.
If you try this with 4 ouputs routing, the problem will occur on the 3d one again.
I made a video if needed.
Best
John
Best
John
