NDLR via MRCC no activity when using USB
Hello,
I received my NDLR today, successfully updated the firmware and I'm trying to use MRCC's USB Port A (using the cable which I received with NDLR) to send NDLR's MIDI out to my synths. All synths are connected via DIN,
No computer involved.
For testing, I've set NDLR's MIDI config to 4 all, 1 all, 2 all, 3 all. MRCC shows no activity at all on any virtual cable in Port A (the same when I try port B.
For testing, too, I've set my synths to omni mode.
When using DIN, there is no problem, but I try to save MRCC's precious last two free DIN in ports for other controllers, and the USB option between MRCC and NDLR looks much more elegant to me.
What did I overlook?
P.S:The blue LED over MRCC's device port is always on, no cable connected. Is this normal?
I am not seeing that you are routing USB A to anything in this scenario, can you please pick one of the USB A inputs (left button below port + any of the first 4 ports out to select) then select an output to route it to, (with no other buttons pressed press a button below one of the output ports, it will become lit blue). Then MIDI traffic should become visible on the routing.
Let me know if that isn't happening, preferably via email at Support@Conductivelabs.com.
(11-09-2024, 09:12 PM)Jesse Johannesen Wrote: I am not seeing that you are routing USB A to anything in this scenario, can you please pick one of the USB A inputs (left button below port + any of the first 4 ports out to select) then select an output to route it to, (with no other buttons pressed press a button below one of the output ports, it will become lit blue). Then MIDI traffic should become visible on the routing.
ATM, I'm routing port A out (green LED) to all DIN outs with a synth connected (DIN out 2 to 5, 1 is currently unused). MRCC's activity matrix (Ax4 and U1) shows the yellow rectangles. I've tried all 4 routes using the same virtual line and all using a separate line.
I had to update MRCC's firmware to the latest version to make it work. Everything A-OK now.
After I updated MRCC's firmware, too, everything works now.
