12-15-2021, 07:02 AM
Hi, would it be possible to connect a sustain pedal in one of the 1/8 jack and configure this input to have the pedal send a midi message (specifically send Rec command to the Octatrack)?
Sustain pedal to send midi?
12-15-2021, 07:54 AM
What a great idea! I have three expression pedals and I was wondering how I could use it in my setup. This could be brilliant!!
12-15-2021, 04:16 PM
No unfortunately these jacks are only for MIDI data. That would be pretty sweet though. Nothing to stop you from using the pedal with a MIDI controller and sending that CC date to the target of your choice through the MRCC, however.
12-15-2021, 04:28 PM
(12-15-2021, 04:16 PM)Jesse Johannesen Wrote: No unfortunately these jacks are only for MIDI data. That would be pretty sweet though. Nothing to stop you from using the pedal with a MIDI controller and sending that CC date to the target of your choice through the MRCC, however. You mean like pluging the sustain pedal to a keystep pro for example and changing that cc message with the MRCC to achieve something else (like triggering Rec on Octatrack)?
12-15-2021, 04:52 PM
(12-15-2021, 04:28 PM)Julien STG Wrote:(12-15-2021, 04:16 PM)Jesse Johannesen Wrote: No unfortunately these jacks are only for MIDI data. That would be pretty sweet though. Nothing to stop you from using the pedal with a MIDI controller and sending that CC date to the target of your choice through the MRCC, however. There is no expression (0-127) pedal input in KSP - only sustain (0/1). Most of portable gears have no any input or sustain only. And only one...
12-15-2021, 05:16 PM
Yep, I just tested a sustain pedal in KSP and it doesn't send anything out of the KSP.
12-16-2021, 02:50 PM
Users browsing this thread: |
3 Guest(s) |
