I'm having trouble syncing the NDLR.
When MPC is master, the NDLR seems to keep its own clock but running at the incoming pace, and adjust it constantly to get in sync, like a DJ with turntables, nudging, a little faster, a little slower, etc., you can clearly see it happening watching the tempo indicator. Sometimes it just dropped to 3/4 speed when starting, totally mismatching.
The other way around, which I don't want because then the MPC can't select (and store) the patches for my synths, doesn't sync nicely either. First it was receiving double midi or something, through the interconnected USB cable which I thought I was just using for power. It was running 2 times too fast. Anyway, at the right tempo, it's not tight at all.
Uhm...
The unit should be able to be a tight midi slave, right?
Hmm I've been reading up on the MPC Live midi clock history. On the interweb. That's not hopeful.
I'm running a recent enough firmware for the known issues to be fixed....
That wobbly clock is probably courtesy of MPC Live.
There goes my plan for this little setup
Uhm...
