Backup Settings (routings etc..) before firmware upgrade ? Howto?
I want to import my settings after upgrading to the new firmware.
So i search for a way to save/export all my settings and load/import them after i upgraded to the new firmware.
How can i do that?
thx
You can remove the left side endcap, and there's a microsd card in there. You can copy the contents of the card to your computer. In general, firmware updates will not disturb your presets unless you reset the MRCC to factory defaults. Good idea to make a backup though if you have a complicated set of patches.
(10-27-2025, 10:32 PM)Darryl Wrote: You can remove the left side endcap, and there's a microsd card in there. You can copy the contents of the card to your computer. In general, firmware updates will not disturb your presets unless you reset the MRCC to factory defaults. Good idea to make a backup though if you have a complicated set of patches.
thx very much for the answer.
regards
