MIDI Clock Sync Latency Issue with MRCC and External Hardware in Ableton Live
I'm experiencing an issue when connecting my external hardware to Ableton Live via the MRCC virtual input.
I would like to use my external gear as if it were plugins inside Ableton Live—meaning, when I press the Start button in Live, I want my external hardware to start in perfect sync with the Live project. However, I can't seem to find the correct settings on the MRCC to compensate for the hardware latency within Live.
My external hardware setup includes:
  • Elektron Analog Rytm MKII
  • Elektron Analog Four MKII
  • Roland SH-4d
  • Korg Opsix MKII
Here's what I've done so far:
  • I selected Virtual Input 1 on my MRCC.
  • Then I routed MIDI outputs 1, 2, 3, and 4 to Virtual Input 1.
  • I connected the MRCC MIDI Out ports to the MIDI In ports of each piece of hardware.
Now, I can successfully send MIDI clock data from Ableton Live to my external hardware.
In Ableton, I went to Preferences > Link, Tempo, and MIDI, and under the Output section, I enabled 'Track' and 'Sync' for all 4 MRCC ports. I set the MIDI Clock Type to Pattern and the Hardware Resync Mode to Stop and Start.
After that, I recorded a drum beat from my Elektron Analog Rytm to check for latency. It was 13 ms off from the grid. In the Link, Tempo and MIDI settings, I tried entering -13 ms in the MIDI Clock Sync Delay section to fix the latency, but nothing changed — the 13 ms delay was still there.
I also checked the settings on my external hardware — all of them are receiving MIDI and clock data correctly.
Has anyone else experienced this kind of issue before? If you can help me solve it, it would be greatly appreciated!
The short answer is there isn't an setting for that on the MRCC. The round trip MIDI time to send data from the computer to the MRCC and back to the computer is about 3ms at the longest by our tests. The only reason that I can imagine for more latency would be if you were absolutely flooding the buffers with data by sending something like multiple fast MIDI LFOs or something along those lines. If the delay exists it's likely to be another factor. I don't have any of the gear you're testing in the lab currently so I can't try and reproduce the issue on my end, but if you want I can set us up a video call to go through it and see if I can find any points where an issue stands out. Send me an email at Support@conductivelabs.com with your availability and time zone.
