Rotator/Pattern Editor Values
Hi all
Im using an original version NDLR with the latest firmware--both rotator and interval algos are present.
When following the instructions for setting up the intervals in the rotator algo, I'm noticing that my pattern values only go up to max 20.  20 is not the midpoint so I can only add lower intervals.  When researching and watching the various tutorials this was not the case.  I have loaded and am editing pattern 40 as shown in the videos.
Possible Im missing something?
Thanks
Ryan
Ok I'm not 100 percent sure about this one, as I don't use this entirely that often, but I believe that it's possible that the issue might be with the pattern's note pool settings if you go into the pattern editor and use the lower left encoder to move all the way to the left, past step 1, it should bring up a menu with 3 options: chord notes, scale notes and chromatic. Selecting a value other than chord notes may open up a larger pool of notes. Let me know if that doesn't solve the issue and I'll take another look.
Thanks Jesse, that did it.  I did not ndl around with the settings enough.  Im ashamed Big Grin
Ry
