Generating MIDI Program Change Messages
To whom this might concern (Steve?),
There are certain MIDI devices (usually legacy devices) which do not have the ability to transmit MIDI Program Change commands.
Furthermore, there are certain, so-called "MIDI Controllers" which also lack this ability, despite being highly-competent in all other aspects (yes, Arturia, I'm talking of you and your wonderful Keystep range!).
While I know I can almost certainly employ BOME with their Bome MIDI Translator product, this is not suitable for a DAW-less setup where my laptop will hopefully be at home(!).
As such, can the Conductive Labs "MRCC" be used as the 'device in the middle' to translate an incoming MIDI key command (or other MIDI notification such as a specific CC message) and then translate that to an outgoing MIDI Program Change message (or even messages?)?
Thanks for any consideration of this!
Regards,
Steve.
