10-17-2019, 08:10 PM
Hi all,
Could a NDLR motif play a drum machine? For instance, if the drum is set to MIDI channel 10, and expects certain note values for the 8 different drum sounds. How is this typically done? Could I connect a keyboard to the NDLR for the MIDI-learn part that the drum machine needs to assign the notes to the sounds? Or just dial in a "one note" pattern note by note to teach the drum?
Thank you for any tipps!
190531085100
190531085100
