Constant Midi clock
Hi there,
is there a way to disable the constant midi clock ?
I am running the NDLR into a MIO10 patchbay and it drowns the other midi information i am afraid.
Would it not make more sense to send start, clock or MTC messages when a part is running ?
Typically when viewing MIDI messages you can filter out the real time (aka Clk) messages.
If you really want to turn off the clock-out you can do that in the Boot menu.
1) Hold Shift+Menu when turning on The NDLR.
2) Motif1 on/off button will toggle Clock Out on or off.
3) The Panic button exits this menu.
Steve
(07-29-2019, 01:57 PM)Steve Wrote: Typically when viewing MIDI messages you can filter out the real time (aka Clk) messages.
Steve
Thank you :Smile
yes, that is perfect.
Are there some combination possible ?
Like, clock out when starting a part...or parts starting on start/stop signals from the rest of the rig ?
I am trying to incorporate the NDLR with the rest of the setup more...
Maybe the constant clock is a good thing...i am not sure yet which should be the master clock.
