07-25-2024, 12:00 PM
(This post was last modified: 12-24-2024, 03:29 PM by RadekPilich.)
Just scratch that
This might be a stupid idea, anyways as I am struggling a bit with where to place the MRCC, I would at least theoretically welcome the ability to rotate the display 90 degrees to be able to read and control it comfortably in case the unit is placed / mounted vertically.
Obviously if the screen is not regular square with same horizontal and vertical resolution then it's a no-go, but if x=y, then maybe the display could be rotated via firmware?
Display rotation for vertical placement
