freeze on startup with midronome
having issues with the mrcc and the midronome. if i have the midronome plugged in via usb (receiving power from mrcc), when i start the mrcc it hangs on startup. it works fine via din cables, but then the problem is that the midronome only has midi in via usb.
edit: it seems to only be an issue when both my midronome and befaco cvthing are plugged in at the same time.
