01-13-2024, 04:14 PM
I recently got a NDLR and I am trying to make it work with the soft synths in logic audio.
I load 4 soft synths, each set to a different midi channel but when I use the NDLR, all of the midi info for pad, drone, motif 1+2 is played by each soft synth at the same time - they should all be on their own individual midi channels.
Midi info is being transmitted over USB from the NDLR to logic
I cant figure out out how to send the midi info for drone, pad, motif 1+2 (from the NDLR) to each soft synth - any thoughts or ideas where i can find a solution for this?
This may ultimately be a Logic midi configuration thing rather than a NDLR thing...not sure at this point, but I thought I would check here first before I start digging around
