Hi, I connected my old Casio WK 3000 Keyboard over Midi Out into the 3th Midi Input of the MRCC. Then I route it to P01 Out. In my Daw (FL Studio) I can play now the MRCC Midi and it works fine.
But now I want to add a transpose mod to it.
So I went to the routing section and selected the out port so it says 3 -> P01. I adding a Transpose Preset 1 to the first mod slot.
Now by pressing the knob dile, I will be in the transpose settings window. Here I can set the transpose for the preset 1 and nothing happens.
Still the same key.
I literally followed the instructions of the MRCC YouTube video for Transpose (Transpose Mod Tutorial by MRCC)
Doesn't matter what preset I choose, what mod slot I use or if I use a different P Out or Midi In Port.
Midi Channels set on Any in the Transpose page but It also doesn't matter if I change it to the Midi Channel I use.
I even tried to factory reset the MRCC, Updating the newest firmware to MRCC_v1.1.073 and trying to use a different midi synth (Novation Circut Tracks) to send the Keyboard Midi to it and transpose it.
Because I thought that maybe my Keyboard was too old, I also tried sending Midi from the Novation Circut Tracks into my Daw. Also no transpose, It stays on the same normal transpose.
Nothing works, it's like the transpose mode doesn't do anything. I think it is a bug :/
Here I put some pictures of my settings:
[/url][url=https://www.playbook.com/s/marcusuniverse/mrcc-transpose-bug]https://www.playbook.com/s/marcusuniverse/mrcc-transpose-bug
Still the same key.
