08-08-2023, 09:59 PM
So the manual says I can send CC 73 to change the key of the NDLR
You can see a snapshot of my Ableton session here - see the track labeled 4 MIDI has a clip that is sending CC on 73. The track is set out to send on NDLR (port 1) out to NDLR via USB.
![[Image: Screen-Shot-2023-08-08-at-9-51-57-PM.png]](https://i.ibb.co/LhsGJRG/Screen-Shot-2023-08-08-at-9-51-57-PM.png)
Also here are my MIDI settings in Ableton, note that I have clock working where Ableton is the master (when I press play in Ableton, the NDLR starts up and is synced to Ableton's clock.).
![[Image: Screen-Shot-2023-08-08-at-9-55-42-PM.png]](https://i.ibb.co/FWvNcfp/Screen-Shot-2023-08-08-at-9-55-42-PM.png)
to I had to enable the "Track" preferences for output "NDLR (Port 1)" in order to see it as a listed midi output port (see below) otherwise it wouldn't show up.
![[Image: Screen-Shot-2023-08-08-at-9-57-58-PM.png]](https://i.ibb.co/zstHW5W/Screen-Shot-2023-08-08-at-9-57-58-PM.png)
But anyways, no matter what value I set the clip's CC value (in picture 1), I don't see the NDLR LED screen changing to reflect any key changes.
