02-26-2023, 11:13 AM
On my MRCC it's often hard to tell if a PC OUT Port LED is lit (blue) or dim (pink). The difference is really subtle – even if I look at it from different angles. I tried all LED brightness levels, but that doesn't solve it. I assume it's mainly a hardware issue, because it's worse with some of the LEDs.
I guess a solution would be to switch the dimmed LEDs just completely off in a firmware update. Would that have any downsides?
