01-29-2023, 06:23 AM
Hello,
I was browsing the forum for some time and checked the manual, but I can't seem to find an answer to my question/idea for the live setup.
What I am thinking about is, using a small midi controller, plugged into INPUT 01 of MRCC
The main MIDI keyboard - IN 02 of MRCC
A number of rack synth modules plugged into OUT 1-8 DIN out
And being able to change which synth/port the main keyboard is sending the messages to, using the small MIDI controller from INPUT 01
The 3 solutions that came to my mind are:
- Changing MRCC presets from the midi controller, and having a different routing on each one of them - this doesn't sound ideal
- Hooking up "BLOKAS MIDIHUB" between the main midi keyboard and MRCC - and change the output midi channel based on the midi note from some small midi controller plugged to the MIDIHUB as well
I would like to avoid involving a PC for this, also part 2 of the plan is to control SampleTank Reverb and Delay over midi from the same small midi controller, on the other side of the studio, a bit further from the FX themselves and MRCC itself...
Is there any easier way of achieving this by any chance? Seems like a simple thing, but somehow I can't come up with a better solution.
Any help is much appreciated.
