MRCC bricked after FW update
After trying the latest FW my MRCC bricked when sending the file via Teensy.
no screen, no leds, Windows gives an error message it no longer detects the device.
Tunring it off and of gives an error Chime and message in windows, but no joy.
How can I reset the unit? I need to work.
Teensy does still react to the button on the side then sending the FW, but the units remains dead.
It’s all good, tried to load a NDLR FW, which as residing in same dir. So i put bootloader to receiivng, but it never got what it was waiting for, loading the right FW worked.
This is the number one reason that we see this issue in my experience. It's always the first question I ask in troubleshooting: "Are you sure you didn't accidentally download the NDLR fw?" Incidentally, the FW runs just fine on the MRCC, it's just that nothing does anything because the pins aren't connected to the right things! Glad you got it sorted so quickly and hopefully this post will be helpful for the next user.
Cheers!
