Show a message when the max number of routings is reached
I just spent an hour trying to figure out why I wasn't able to map any routings from the PC outputs to DIN plugs.  I just happened to hit the max number of routings with no PC MIDI routings enabled, so I thought something was broken.  Rebooted, restarted the MRCC, swapped USB cables, etc.  I didn't even know that there WAS a max number of routings until I happened across another post on this forum (it doesn't appear to be listed in the manual either?)
A simple message popping up on the display screen that says "max number of port routings (50) reached!" would have saved me some troubleshooting time.
I'll add this request. It sounds like it would be a good one for sure.
