10-14-2022, 06:57 PM
I just ordered an MRCC and my plan is to use it with an iPad Pro as my central "control plane" for everything audio and MIDI. I will have all my synths' MIDI going through the MRCC and all my synths' audio going through a Scarlett interface. Both of the Scarlett and MRCC will be plugged in to a USB hub and I will be using AUM to manage everything on the iPad.
After ordering everything, I got a horrible feeling when I realized I wasn't sure if the MRCC will work correctly when not plugged directly into my iPad but through a USB hub (using an Anker hub if it matters). Will I run into any issues? I ask because I've had issues in the past controlling USB of MIDI devices if they were going through a USB hub.
To be clear, I am not trying to use the MRCC *as* a hub, I want to connect it to my iPad *through* a USB hub. I wanted to call this out as I saw some other people asking about using the MRCC as a hub.
Thanks in advance!
Thanks in advance!
