09-29-2022, 03:38 PM
How are you guys exporting or recording the midi from the NDLR to your DAW of choice?
I've tried a couple different ways, to no avail. I'm using Studio One and couldn't get it to work.
I'd like to be able to discretely record the midi of each part to its own midi channel. Everything
would have to be in sync, of course. Studio One needs to be sending out sync, it won't work as
the slave, (too bad) unless you sync to midi timecode which the NDLR doesn't support.
I also tried it with my mpc1000. Although, it seemed to handle one channel
of midi recording fine, it can't record all channels at once, which is less than optimal.
From what I understand, the squarp pyramid can multitrack midi, but that seems like a bit much.
Has anyone here gone down this particular rabbit hole?
