BUG: Label assignments not logical enumeration
Today I've discovered an issue with the labels in the MRCC
The assigned label positions seem to move when adding new labels.
i.e. If you create 4 labels: Synth 1, Synth 2, Synth 3, Synth 4
and assign them to midi in 1,2,3,4
Then create a Synth 5, then the assigned label positions move, i.e. midi in 1 is no longer assigned to synth 1, but synth 2
It seems the way it enumerates is absolute sequential and not logical.
The consequence is that when buying or selling gear and because of that creating new labels, you'll need to validate all ports for still having the correct label.
Is this a known bug?
can this be fixed?
Not a known bug! I will see if I can repro this and let Steve know to take a look at it. That shouldn't be too much trouble to track down if it's doing that.
(03-07-2022, 10:36 PM)Jesse Johannesen Wrote: Not a known bug! I will see if I can repro this and let Steve know to take a look at it. That shouldn't be too much trouble to track down if it's doing that.
Would you be so kind as to let me know what fw version you're using please?
ThnX Jesse, it’s the latest beta 0.44
I tried setting up an experiment to reproduce your issue, but instead of having my labels displaced, all of my routing label assignments suddenly disappeared when I added a new label to the pool. I have passed the word up the ladder and hope Steve can get to the bottom of this shortly. I'll let you know when I have a solution to try out.
Maybe that’s what’s going on, I was focussed on in 1, something is off.
