02-14-2022, 01:37 AM
Can someone help with my issue
Here it is
I'm trying to connect a sequencer (deluge) to the ndlr using using deluge as master clock .
The issue I found is when I connect a drum machine to this setup i can't seem to sync the transport on the drum machine. It's running at 300rpm! (Syncs fine when connected direct to the deluge though)
I seem to be getting some midi feedback loop or similar
Can someone provide a solution?
Here is my setup now:-
1. Deluge midi out to ndlr midi A in.
I want to control the ndlr from the deluge and program notes etc on the deluge. I can get this to work as long as I don't add a drum machine/groovebox into the midi chain (see below)
Midi Chain
2. Ndlr clock set to ndlr midi A (thats from the deluge) and ndlr pad set to midi 1, drone to 2, motof 1 to 3, motif 4 to 4.
3. Ndlr midi A out to midi splitter box (to split the midi to the synths and drum machine)
4. Midi splitter out channel 1 (pad) to synth A, channel 2 (drone) to synth B , Channel 3 (motif 1) to drum machine channel 3, and channel 4 (motif 2) to drum machine channel 4
5. Synths all work fine but the drum machine won't sync with the transport from the deluge . Its runs at 300rpm! Taking the ndlr or the midi splitter out the chain removes the issue so it's nothing unexpected .
So there appears to be an issue with clock where more than 2 sequencers are in the mix.
Any idea how to fix much appreciated
Here it is
Midi Chain
