Channel Map: Input Channel "none" missing
Hi Forum!
In the manual on page 29 in the chapter "Channel Map Sub-Page" in the section "Channel In 1-4" it is mentioned that as incoming channel besides the mandatory 16 MIDI channels also "none" can be selected.
Unfortunately the manual seems to be ahead of the current firmware version. On my MRCC with version 1.1.037 this selection option is apparently not available or I am unable to find it.
But since I would actually use this option all the time, I wonder when this function will be delivered?
Thanks
Andy
Good Question, I don't remember what the status of this should be, but having a None does seem to make the most sense. I will ask Steve to consider taking a stab at that.
Thank you, Jesse.
Are there any new insights about this in the meantime? It would be great if the MRCC soon works as described in the instructions. Wink
No update at this time but I will put this on the list of things I will push for next time I'm in the office and see if I can get some progress on it. Thanks for the reminder.
-Jesse
3 Guest(s)
