12-10-2021, 01:46 PM
		So far the MRCC has been great, connected via Midi IN/OUT to my MioXL
Now I want to use it directly in Cubase and I get confused
The MRCC PC Port has a green light (called IN) andf a Blue light (called out)
I assume the green PC light is the traffic FROM daw to MRCC and the blue PC light is the traffic from MRCC into DAW, is this correct?
This is what I then do
I have a synth connected to midi out 1 (DIN) on the MRCC
I select the left PC button (green light) virtual port 1 is selected, I let go and select midi out 1 (blue light)
In cubase the I can select MRCC until MRCC12
I select "MRCC" as output (this corresponds with virtual port 1)
I have the correct midi CH selected in Cubase (in this case 1)
I play a sequence in Cubase
NOTHING happens
I'm probably doing something wrong, but what?
What is the correct way of playing a hardware synth connected to the MRCC Din out, from Cubase, over USB PC connection.
Pls advise?
NOTHING happens
Pls advise?
