multiple connection problem
with the MRCC I am finding that if I use the 5 pin connection as well as the 3.5 connection ie midi in port 1 and 6 and it looks like the out ports may be the same, I have to unplug all but 1 connection to be able to use it which is a bit ridiculous as I should be able to leave things plugged in and be able to select what I want to use or auto detect where the midi signal is coming from or else there are a few ports I wont be able to use is anyone else having this problem or do I have a faulty one ? Thank you
