NDLR and Eurorack
Greetings, all!
Done a bit of searching here and there and just thought I’d see if there’s any new/better ways to connect the NDLR with my Eurorack system or if the CV.OCD is still the way to go?
Thanks in advance!!
John
CVOCD only has 4 CVs so if you are hoping to use just the motifs and drone, then it's a good option, I've confirmed it works. I also have the Polyend Poly2 which has just a metric Sh**Ton of CV channels you can set up, so if you had enough voices you could even send the Pad Part. I have not set mine up for use with the NDLR to comment on it's effectiveness however.
