07-31-2021, 11:49 AM
Hey There folks.
Happy recipient of the MRCC here... its a bit of a game changer for my room.... no more reaching for MIDI cables or re-plumbing every other day... Hooray!
I have found a little idiosyncrasy though, this might be a very fringe case but non the less....
I am using a Novation Circuit Tracks MIDI via USB Host A, when I patch this through to the MIDI Din port 1 on channel 1 to drive a Buchla Easel command 208C all is good... until I start navigating around the Circuit Tracks. The Sysex messages sent when changing a view or page on Circuit Tracks seem to be randomly combining with a note message to trigger a very high note. I noticed that some of the MIDI notes are also being stopped outputting while navigating around the Circuit Tracks too.
This is also the same on the Circuit Rhythm again I'm fairly certain it's caused by the sysex messages being sent out of the USB on the Circuits.
When I switch to a Din output on the Circuit Tracks or Rhythm this problem is not there. The sysex messages are not being sent out of the DIN ports on the Circuits so that makes sense.
The issue is also not there when I send MIDI from Circuit's USB to other synths either so it could be something within the Buchla 208C's MIDI implementation not enjoying being sent a spurious sysex message.
So for my two pence.... it would be great if Sysex was a filter option which I think would solve the issue from an MRCC perspective.
I work at Novation too so I'll be asking the engineers about the need for these sysex messages. I'm not 100% certain they are actually needed unless its a requirement for the Novation components software to manage the synth editor in Circuit Tracks. I certainly don't see any particular need for these Sysex messages in the Circuit Rhythm though.
The good news is that I can confirm that (except this strange sysex thing with Buchla) the Novation Circuit Tracks and Circuit Rhythm are class compliant enough to happily work with the USB host ports. As does the Summit and Peak synths.
I'll be testing out the Launchpads Mk3's Launchkey Mk3s, SL MKIII, Bass Station 2 and the LaunchControl XL in due course soon too so will report back on their compliance.
Sadly the Monome Norns music computer isn't class compliant enough for MRCC to show up via USB though.
Other than this small (and not insurmountable) issue MRCC is a joy to use and is taking pride of place in the studio.
Cheers
-CALC-
Cheers
-CALC-
