USB Midi Clock runs at 2x or 4x with Deluge
(01-08-2021, 10:16 PM)NoSoulToSell Wrote: I know this is a little off topic, but i just got my NDLR a couple of days ago and I am trying to sync via midi from my Deluge.  I have got it sync'd, but when I stop the Deluge and restart, the NDLR just picks up where it left off and does not restart from the beginning.  Anyone know how to fix this?
I guess this is the normal behaviour, the NDLR waits for MIDI Clock in a certain resolution (96 PPQ) and then starts with the modules that where running when the last start command was received (unlike what you manually started/stopped)
What you would like is what I have found under the name 'mungo-sync', this functionality is also in a MIDIPAL and I actually try to do this with the MIDIHUB - with no results at this time.
