12-29-2020, 09:27 AM
Hi everyone,
I am trying to set up my newish NDLR for use in Reaper, and was hoping someone here can help me with the following:
1) I would like to send clock from NDLR to Reaper. When I change the tempo on NDLR, however, I do not see the tempo in Reaper changing. How can I get Reaper to receive and respond to external MIDI clock?
2) I would like the Reaper transport to start and stop when I press the master play/stop button on the NDLR. Can someone please advise how I can set this up? I have tried assigning the main play button in Reaper to the NDLR master play/stop button on NDLR using the Actions menu, but it appears to assign notes within Channel 15 (the NDLR control channel) to the Reaper play button depending on the motifs that are going at the time.
Thanks in advance for your help!
. I am relatively OK with basic operations. The easiest thing to begin using it is to make sure you "insert virtual instrument on new track" when you want to load a VST - this will ensure that all of the routings are correct in order to use an external midi controller (such as the NDLR) to play that synth.
