10-21-2020, 12:39 AM
To support better automation from a DAW, please change the range of CC 26 by adding the value of "8" to represent "the latest played chord degree".
The use case for this is the following: imagine you're improvising using a combination of NDLR and DAW. You want to trigger some automation in the DAW that - wherever you are in your music - re-starts the drone without needing to remember what is the latest chord degree you were playing, so you just send a CC 26 of 8, and whatever that was it is triggered again, and the drone starts.
This idea is originated by what looked like an automation issue to me originally, described here.
Thanks!
G.
Thanks!
G.
