  • 1 Vote(s) - 5 Average
Load and save global settings with MIDI
Hi All, I've searched the forum and I haven't found anything about this.
When using NDLR from a DAW, how useful would it be if the NDLR could load and save its entire global settings with MIDI CCs? In most cases this would be more convenient than programming the individual changes for the parameters using, for example, a DAW's automation.
E.g. I'm working on a piece where the pad does a "solo" at some point where position, strum and range all change, to feel more improvised. At the moment I am manually loading the new global settings when it's time, but it may be much more convenient to trigger the same from the DAW.
Thanks!
G.
