Global Save Small Bug
I'm using fw 1.1.070 and I found a little interface bug when using the Global Save function.
If you click shift with the top-right knob in order to save the selected global settings and you press the menu button in order to exit the settings while the Green Saved box is still present on the display then in the main page the contral box with the pad or motif info is disappearing when the green box sends the hide command.
I attach a video to show the behaviour.
https://youtu.be/Wns5zJg7TqQ
Bye,
Claudio
(09-07-2020, 02:33 PM)Mescalina Wrote: Hi,
Bye,
Claudio
Thank you for reporting this Claudio, and the video clearly demonstrating the issue! We'll get it in the bug tracker.
A quick work around if this happens, is to turn a couple of knobs that affect the context menu and it will redraw.
Bye,
Claudio
Hi Derryl,
yes, I've noticed that the menu is redrawn when you touch a knob, it's not a great bug but I signaled it when I saw it.
Another bug, which is more annoying is that in many menus when you turn the knob it doesn't work properly unless you first turn it in the opposite direction.
Thank you,
bye
