Threads: 3
My new MRCC is great, except when I am turning the knob to do various tasks, it gets to a rotation point and becomes very stiff. I turn past it and it eventually stops being stiff. Turning it backwards, it becomes stiff again. Does this happen to anyone else?
Threads: 52
Not in front of mine, but it sounds like maybe the knob was fastened off-center. Look at it from the side to see if one part of the knob is lower than the other.
I forget if it is a push-on or a set-screw. If a push on, the actual pot shaft may be bent. If a set screw, loosen the set screw, readjust the knob, and tighten.
