Purchased MRCC 880 to connect the following equipment:
Arturia AstroLab
Arturia Minifreak
Native Instruments Maschine Plus
Focusrite Scarlett 18i16 Audio Interface
Kali Audio IN-5 Speakers
All the Equipment works great and we have sound out of the speakers through the Scarlett.
I need help though with the MRCC 880 and midi setup so all the three hardware stuff above work together.
1. Do you route all MIDI OUT from the 3 devices to the MIDI IN into MRCC 880?
2. Do you route all MIDI IN from the 3 devices to the MIDI OUT into MRCC 880?
I don’t then understand what the MiDI settings should be for each individual piece of hardware, it’s frying my brain.
Would also like to know if i got the FIRMWARE installation right?
The 1st time after I followed the instructions and I put pin into the machine it went green to input no 4 permanently.
I did not think this was right so started the process again and when I put the pin into the the machine it flashed colours went green and blue from 1_8 and stayed on in no 1 green.
So i don't know if this worked or unit is working?
Help would be more than appreciated.
Arturia AstroLab
Arturia Minifreak
