5 hours ago
Has anyone used their ? I use the NDLR as a controller hub for 3 - 4 hardware synths and have had no issues connecting them with 5-pin midi.
However the Edge behaves oddly. It works as intended with other midi gear like keyboards and as a slave for other hardware synths.
When I connect it to the NDLR for motif or drone duty it will trig once but then not trig again. If I trig the Edge manually with the dedicated trig button or by external cv though it's patchbay it will play the motif as intended until I remove the trig source. Almost as if the NDLR does not send sufficient velocity to it. NDLR CC value is set to 127 and 75% and changing those does not help.
A very specific issue and not very important, but it annoys me that I don't understand why it behaves like this.
