01-25-2024, 05:44 PM
owned the original and bought a new ndlr v2 and got here last week. but the kb trans function is acting really weird .
i've tried all ports and different controllers to different synths all with the same result .
when i press the same key (any key) repeatedly it starts to climb in scale and then back down as if there is a midi feedback loop .
i'm using all stand alone linear hardware, 5 pin midi controller to midi b in to ndlr out midi b and to the synth . powered ndlr by separate usb wall wart .there is no possible way any feedback loop is occurring.
like i said tried all ports and different controllers
i hooked it up to ctrlr.org's midi monitor to see what was happening and the note off number is not matching the note on number and each time the same key is pressed different note on and off values occur
i tried re flashing the firmware but didn't help. all other functions working perfectly fine . monitoring midi messages on the other motifs and the note on # is matching the note off #
perplexed ...
perplexed ...
KB trans issue
