I have a question about the number of mods of one type (e.g. CC) for the whole MRCC. Is it possible that only 6 different modifiers of one type can be created in the entire configuration (not a single IN-OUT routing) ?
If this is true then this is a very small amount (if you consider that it has to support such a number of devices, including USB, which often without a computer you can not change anything and you need to do it on MRCC).
In some cases, I would like to use these 6 CC modifiers for only one device... and is this the end of the possibility of changing CC? I hope I'm wrong...
6 CC modifiers is half CC modifier per one of 12 outputs (while we use many cc per device)
