Hi all,
My MRCC is currently on order. I'm buying cables while I wait for delivery, but I'm a bit confused by MIDI TRS.
I have a 1010 Bluebox mixer which has 3.5mm MIDI TRS in and out ports, and I plan to connect them to the MRCC.
Since MRCC has separate ports for both MIDI TRS types (A and B), can I just buy a normal 3.5mm male to 3.5mm male stereo audio cable to connect them?
Presumably, if I plug it into the TRS B in and out ports on the MRCC, it should just work given that the Bluebox supports type B for in/out, right? No special cable required (eg. crossover or whatever)?
Many thanks,
Ben
Many thanks,
Ben
