Hi, new user of The NDLR here.
I have the Novation Mininova connected as Pad; about 10 notes, medium range, position, strum, 60 BPM external Midi clock. All works fine.
When I set up the user-LFOs 1 and 2 to 40s, saw or square, and select Global Key and Chords as their targets, the pad plays changing keys and chords. Fine.
The odd thing is: when I set the probability to low values, say 1, the keys/chords still change up to 15 times in just 2 minutes. Way too often, as if the probability parameter is ignored. Even with 0 the keys/chords still change (though zero prob. should mean that no modulation is taking effect at all).
What am I missing? Thanks for any hints,
Cee.
Cee.
