06-01-2021, 02:18 AM
I have had the NDLR for a few months now, and I'm loving it.
However, I have been having an issue with the pattern and rythm editors. In my setup, the NDLR is controlled by a MIDI track on my Digitone, which sends chord changes. If I open the pattern editor while the Digitone is sending MIDI to the NDLR control channel, the NDLR will cycle through the steps of the pattern and change their value randomly (which is not what I want). The same occurs with the rythm editor. The only workaround I have found is to mute the MIDI track controlling the NDLR while editing the pattern (or rythm), but this is limiting because I would like to edit the pattern (or rythm) in the context of the chord progression I'm playing. Please note I had the same issue in a different setup with a Beatstep Pro controlling the NDLR.
I would be grateful for any help you may be able to provide.
Many thanks,
Salvatore
Many thanks,
Salvatore
