click button not working properly.
Hello. One of my 'click' buttons is working intermittently, sometimes taking 5 or 6 pushes before it changes to that chord. Can you tell me what the button is (i'm guessing they're cheap) and how simple it is to replace?
Rob
(02-24-2021, 01:56 PM)rob-ant Wrote: Hello. One of my 'click' buttons is working intermittently, sometimes taking 5 or 6 pushes before it changes to that chord. Can you tell me what the button is (i'm guessing they're cheap) and how simple it is to replace?
Rob
Hey Rob, if you're comfortable with the repair I imagine I could even send you the part. Please send me an email at Support@conductivelabs.com and I'll run it by the boss.
Thanks,
Rob
Thanks,
Hi Jesse
The buttons appear to be a few pence so I'll just buy one but can you tell me which I nee.
Rob
Rob
Thanks,
Hi Jesse
Rob
Can you PM me the Serial Number? certain units have different part numbers so I want to make sure you get the right one.
Rob
Thanks,
Hi Jesse
Rob
Hi Jesse
Serial number: 011-0325-1909
Rob
Thanks,
Hi Jesse
Rob
Hi Jesse
Hey Rob, here is a link to that part on digikey:
https://www.digikey.com/short/z0rh8p32
I imagine that won't be any issue to replace, I recommend using side cutters to clip all four legs then use a soldering iron to remove each leg and solder wick (or solder sucker) to remove the solder in the holes afterwards before putting the new one in.
If you do run into trouble though, let me know.
