Hi All,
At the Conductive Labs "Ship" celebration (Nov '18) Craig from Genshi Media Group did a NDLR performance for everyone that was recorded and can be found on YouTube: Conductive Labs NDLR Launch Party Demo Performance.
We had some questions about how the Arturia KeyStep was controlling The NDLR via the Mod Matrix and what was it doing.
The KeyStep was connect to The NDLR using the MIDI 5 Pin Din connected to MIDI IN 'A'.
Craig was doing a few things actually. He was using the KeyStep to change the Chord Type. The keyboard velocity was mapped to the Pad Range (number of notes played) and the Mod Wheel was mapped to the Pad Position. This was accomplished by aligning the MIDI channels between the KeyStep and The NDLR, and mapping the inbound MIDI messages in the Modulation Matrix. He also used The NDLR's note Transpose feature. Here are the details:
1) to change the Chord Degree, this is the chord number like a I, IV, V progression
Thanks,
Steve
- The KeyStep's MIDI output channel (15 in this case) is set to the same as The NDLR's "NDLR Cntl" MIDI input channel (found in System Menu 1).
- The white keys, C-B, map to the 1-7 Chord Degree buttons.
- The black keys map to the Chord Type buttons, triad, 7th, sus4, etc... (see manual for details on the mapping).
- In the Mod Matrix (he used slot #1) the Source is set to Velocity and the Destination was set to Pad Range. The Mod Amount and Destination Value was adjusted to match Craig's preferences. This maps the inbound MIDI Velocity from the device set to the "NDLR Cntl" MIDI input channel to the Mod Matrix Destination.
- In the Mod Matrix (he used slot #2) the Source is set to Mod Wheel and the Destination was set to Pad Position. The Mod Amount and Destination Value was adjusted to match Craig's preferences. This maps the inbound MIDI Mod Wheel value from the device set to the "NDLR Cntl" MIDI input channel to the Mod Matrix Destination.
- The KeyStep's MIDI output channel (16 in this case) is set to the same as The NDLR's "KB Trans" MIDI input channel (found in System Menu 1).
- The KeyStep's notes are being transposed to the current Key and Mode of The NDLR. So playing in the key of "C" on the KeyStep's keyboard will always be in the right key and mode!
Thanks,
Steve
