Threads: 2
I have experience with midi and syncing hardware, and I tried all the logical settings, but my NDLR doesn't recognize the midi clock from akai Force.
MPC force midi clock out-----} NDLR midi din input B , clock external.
I tried usb ndlr clock out, but doubles the timing on the force.
Threads: 42
1
I can't think of any reason The NDLR wouldn't recognize a MIDI clock, unless it has a weird PPQ.
The double clock rate on the Force indicates that there are two clock sources.
Threads: 2
01-15-2020, 04:37 PM
(This post was last modified: 01-15-2020, 04:38 PM by nosebleed.)
24 ppq.
Also, when trying to sync from Ndlr to Force via usb, I just send the clock, I don't send anything else, and i don't have more clocks coming to Force.
I cannot use NDLR right now.
and i think it's more than the xdoublde speed.
Threads: 42
1
Does the Force have a USB host port that you are connecting the NDLR to? If so, then it might see clock on more than one of the NDLRs virtual USB MIDI ports. Can you select which port to receive clock on in the Force setup?
Threads: 2
No, I can't select at which port Force recieve midi clock, it's global. I have the Ndlr conneceted directly to the usb Force usb inputs.
Threads: 0
FWIW I am having the opposite issue - either my NDLR is not sending the MIDI clock (DIN or USB) or it is and the Force no longer recognizes it.
I have tested with these versions:
NDLR FW 1.1066 to 1.1071
Force FW 3.04 and 3.05
I have tested MIDI out settings in the NDLR boot menu with no luck as well.
I am also a beta tester for the Force and the NDLR is the only gear in my studio that does not send MIDI clock.
