OK, really odd. Possibly something Ive done/am doing.
I only received my MRCC yesterday (with the 4x1 expander). took hours to set up lol, noth the MRCC as such, but working out all my routings, and fault finding issues i was getting with the 4x1.
Anyway, got everything working as I wanted it late last night. My MRCC wasnt on the latest FW, (still had to press shift and save/load) so I updated and everything seemed fine.
This morning I wanted to add an extra USB in (for my iridium. I had it into the PC port yesterday as it was the only way I could get it talking, as Iridium is a host too) - I found how to configure correctly. So Im not getting the green LED on the USB port (was getting red before) OPK, all good. Now the problem. I can only make a single routing.... This isnt just on the new port. If I make changes to saved presets I can only make 1... For instance, I can go to input 1, and ADD (to my already working preset) Midi out 8, but iI cant add 9. If I de-select 8 I can then add 9, but cant then add 10 etc.
This was fine yesterday, and before I updated FW (cant remember if I made some changes after or not).
Any ideas at all here? Im SOOOOOOOOOOOO close to having it set up with 4 presets how I need my setup to work. The ONLY reason I changed was I really wanted the Iridium to work in a Host port and not use the PC one, or I cant route into my PC (which I wouldnt do often, do I would want to on occasion).
Any ideas here. Is it that latest FW? if so how do I roll back. Anything else that FW introduced I need to do to make multiple connections?
OK..... More playing.
It seems Im out of connections............ If I removed 5, I can add 5 but no more.
PITA lol
I have each of 4 presets set up correctly at least, but It means I cant add any more gear...... I have a Pro3 to integrate once I move to a slightly larger room - which will need 2 conections (1 in and 1 out) minimum (Id like more - i like to be able to play all my sources from all my keybeds) There MAY be 2 available... or not.
Secondly, I was going to pick up a NDLR once back available, but theres no way Ill have enough routes to integrate that too....
Going to raise this as a ticket... I get that if you have too much data flowing you get problems, but I dont. Im not USING all the connections at once, but a long shot. ITs just so I can go to any keybed, and play and sound source. At worst Ill be playing the sequencer (HAPAX) or NDLR (If I can integrate it) but that wont use all the connections up either.
PITA lol
